InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Move model to 0,0,0
3 REPLIES 3
rcochran
894 Views, 3 Replies
Move model to 0,0,0
I was wondering if there is a way to export my Infraworks model as an FBX so it is closer to 0,0,0 (the origin).
3 REPLIES 3
Karsten.Saenger
in reply to: rcochran
you should be able to export your complete InfraWorks model to FBX format:
Is it this what you are looking for?
Karsten.
Karsten Saenger
rcochran
in reply to: Karsten.Saenger
I figured it out.  I needed to check my units, it was set to metric. I used the FBX output with the extent, change my coordinate system to the correct one.  This populated The offset X and Y, which is the lower left hand corner of the model or polyline box.  I then changed the orign pulldown to user defined and inputed a z elevation that was the lowest elevtion of my ground.  Worked great.
Thanks for the help
kwilktrihydro
Thanks for posting how you got there. I needed this!
Kelby Wilkison, P.E.
Civil Engineer
Trihydro Corporation
Rail Community
