I was wondering if there is a way to export my Infraworks model as an FBX so it is closer to 0,0,0 (the origin).
Solved by rcochran. Go to Solution.
you should be able to export your complete InfraWorks model to FBX format:
Is it this what you are looking for?
Karsten.
I figured it out. I needed to check my units, it was set to metric. I used the FBX output with the extent, change my coordinate system to the correct one. This populated The offset X and Y, which is the lower left hand corner of the model or polyline box. I then changed the orign pulldown to user defined and inputed a z elevation that was the lowest elevtion of my ground. Worked great.
Thanks for the help
