InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
more visual effects?
5 REPLIES 5
randyspear6624
515 Views, 5 Replies
Is there a way to get more visual effects? For example, the 3d wireframe, rendered, conceptual, etc from C3D?
5 REPLIES 5
Currently, there are only a few options like these in InfraWorks. You do have the option to view the project as triangles, and under Visual Effects> Colorize> there is an option for Grayscale and Sepia. There isn't a way to add to these in InfraWorks.
You can export your InfraWorks model as an FBX, then import into 3ds Max Design and use the “Stylized” options for (Graphite, Pastel, Color Ink, etc).
Out of curiosity, how would you use these styles in InfraWorks? What would be your hoped for end result?
Willy Campbell
I was making some walkthoughs of and FG surface but I had to use the wireframe because you can't see the terrain very well with the other setting.
Are these to programs typically intended to be used together? I like the speed of infoworks but since I'm typically using civil 3d outputs, it's not the greatest if you need to show multiple surfaces and differentiate.
Currently, InfraWorks only have the ability to handle 1 surface at a time for any given area [vertically]. Meaning you cannot use InfraWorks to "stack" surfaces like you can in Civil 3D to generate cut/fill volumes, surface comparisons, etc. In Infraworks, multiple surfaces will 'blend' and one [EG or FG] will win out, and the other will no longer be available. This is not to say you cannot have multiple surfaces in a single InfraWorks project, just that there can be no overlapping of surfaces.
Willy Campbell
yeah, i see that... I probably won't be using it for preliminary design as I assume it's intended but with a little more upfront work in civil 3d I'll be able to make better use out of it.
neilyj666
in reply to: Willy_Campbell
No doubt this will appear as a 360 subscription add on....;)
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
