Apparently I can't open an sqlite file on a network drive in 2015 (it works fine in 2014) so what files do I need to copy to my local drive to allow me to access the model in 2015?
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
hi Neil,
you would need to copy the model.splite file and the corresponding model.files folder to your local disc.
Within the current sandbox build it should be possible to store models on network drives. These network drives should be mapped.
Andreas
hey,
the InfraWorks Rolling Sandbox [beta] is a three weekly beta build to test out new designs, features and functions and any feedback will directly go to the development team.
WRT the mapped network drive feature, it will most likely in the upcoming release around November.
Andreas
Not being able to work from a network drive is a big issue with trying to use this program in a production environment. And working in the cloud with large files isn't the solution! Especially for those of us that don't have Infraworks 360.
this looks like this is being fixed in 2015 R3
What's New in Autodesk InfraWorks 360 (2015.3) http://help.autodesk.com/cloudhelp/2015/ENU/InfraWorks-NewInThisRelease/files/GUID-5CD0E45F-B2F7-4A9...
DarrenP
That's good news. Hopefully this will happen on basic Infraworks included with the Suite and not just Infraworks 360.
yea i'm pretty sure this update is only for the 360 version of Infraworks 2015 and not the version that comes with the suite
here is hoping i am wrong
DarrenP
I had the same problem these days , and solved it with the method below.
https://technet.microsoft.com/zh-tw/library/ee844140%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396
