InfraWorks General Discussion
YRogachev
Message 1 of 6 (669 Views)
Invisible edge
669 Views, 5 Replies
12-19-2012 04:03 AM
Why some edges of these buildings are invisible? They was made from shp file, AIM 2013R2. And I have a lot of same buildings with invisible edges in the model.
_____________________________________________________________
Мой опыт внедрения Civil 3D
yrogachev.blogspot.com
Try THIS, on the View tab of the ribbon, toggle on "Show Backfaces"
BrianHailey
Message 2 of 6 (661 Views)
Re: Invisible edge
12-19-2012 05:48 AM in reply to: YRogachev
Brian Hailey
CAD-1.com
My Blog
YRogachev
Message 3 of 6 (657 Views)
Re: Invisible edge
12-19-2012 07:07 AM in reply to: YRogachev
Thank you!
It's works!)
Distinguished Contributor
jmaeding
Message 4 of 6 (248 Views)
Re: Invisible edge
05-06-2013 11:02 AM in reply to: YRogachev
Just saw this, this is so important, it should be checked by default!
I was about ready to model a bunch of houses individually in sketchup and bring in as city furniture method instead of extruded footprints.
SOOO glad you guys solved this and posted on it.
internal protected virtual unsafe Human()
http://onesmallstepforcad.com/
Alfred.NESWADBA
Message 5 of 6 (242 Views)
Re: Invisible edge
05-06-2013 01:09 PM in reply to: jmaeding
The higher the data amout the higher the performance needed on GPU(s) to render faces. To automatically set this options means that every face is rendered from both sides (internally) which might result in performance conflicts.
The switch is necessary when getting/importing geometry that has not oriented the face-normals to the same side (knowing what is inside, what is outside for faces/surfaces), so yes, it has to be activated on some needs, but not as default.
- alfred -
Alfred NESWADBA
jmaeding
Message 6 of 6 (239 Views)
Re: Invisible edge
05-06-2013 01:48 PM in reply to: Alfred.NESWADBA
in that case, AIM has a bug.
Those faces were generated from extruded shapes by AIM.
If it cannot orient the faces outside, which there clearly is an outside to a polygon, its not working.
