Can't change my model extents. I define it by drawing a box around th earea I want to focus on and I get an "Invalid model boundary" warning and have to result in useing the entire model. That is not acceptable b/c when I try to export my story board to a video, I run out of resources which by reducing the model extents, that would not happen. I have attached a screen shot. the blue box I drew using hte "BBox" button. I donlt know why Infraworks refuses to accept the. The X&Y coordinates came in automattically from the box.
changing the model extent should be always possible.
Have you checked if the proposed coordinates are actually valid for your model?
Try deleting the content of the Tile Cache folder usually under C:\Users\<<USER>>\Documents\Autodesk InfraWorks Models\MODEL.files\TileCache
Is it possible to share the model with me so that I can try to recreate the problem on my system with your data?
Karsten.
Hi @juan_soto,
I have re-tested the issue and can confirm the error message if the database coordinate system is set to other than LL84.
For information - the best practise is to leave the database coordinate system at LL84 in InfraWorks.
See this blog post for detailed inforamtion and tips:
Best Practices: Coordinate Systems and Model Extents in InfraWorks 360
Karsten.
Hi @juan_soto,
the explanation why you are getting the error message is following:
What you can do now is to export your model as IMX with the new project boundary.
Otherwise, the only solutions seems to re-create your model with a coordinate system where the defined boundaries match to the actual location of the model.
Karsten.
