InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Infraworks shoreline?
5 REPLIES 5
cguryan
533 Views, 5 Replies
I have a set of elevation data (DEM, TIF, etc.) that includes a shoreline. How do I get Infraworks to recognize a given elevation, say, as being water? I could trace out a water coverage area, but that would be inaccurate. I would think there's a way to indicate that any point with an elevation < 0 is underwater, but I haven't found it yet.
5 REPLIES 5
Karsten.Saenger
in reply to: cguryan
Hi Chris,
what is the desired outcome of this? Is it for visualization only or do you want to extract water aera data?
How about creating a Terrain Theme under Analize your data panel? You could add one theme with certain elevation level and colorize it as desired.
You can smoothe the shoreline by selecting a smaller tile size for the terrain in the data configuration.
Best Regards,
Karsten.
Karsten Saenger
cguryan
in reply to: Karsten.Saenger
Thanks for your response. I need area data for my use; I actually export Infraworks geometry to DAE and import into a modeling and simulation tool. Creating a terrain theme seems to identify the shoreline with sufficient accuracy, but is there any way to get this data out of Infraworks as a set of DAE shapes?
Karsten.Saenger
Hi Chris,
to my knowledge it is not possible to export analysis datasets to vector data (coverages) in the current release of InfraWorks.
I can file a product enhancement wish for you or you file one yourself on the following page:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Karsten.
Karsten Saenger
cguryan
I've found a way around the problem: I used the flood analysis tool in Global Mapper, exported that to shapefile, and imported the shapefile into Infraworks as a water area. Global Mapper is much slower than the Infraworks analysis, but it works. It would be handy to do it all within Infraworks, though.
Thanks.
Karsten.Saenger
Hi Chris,
excellent workaround!
Karsten.
Karsten Saenger
Rail Community
