InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
infraworks for lumion
3 REPLIES 3
alexandre_ssp
1856 Views, 3 Replies
how to export to the infrawork lumion?
3 REPLIES 3
BrianHailey
in reply to: alexandre_ssp
Keep in mind that I have no idea what Lumion is...
There are four option for getting data from Infraworks into something else that I'm aware of.
  1. Export a .imx file and then import that into Lumion (doubt this will work).
  2. Have Lumion connect directly to the .sqlite file.
  3. Export to a .fbx file (probably your best option).
  4. Use the "Send to 3ds Max" command and then use 3ds Max to convert to something Lumion can use.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
karl1112
As Brian said, FBX. Lumion (at least 3.2) will import FBX directly. Keep in mind it will take a while to import, especially trees... just let it work away at it .. its definitely worth the time it takes. In InfraWorks, you might want to export to separate FBX files (bottom of the dialog) and then combine in Lumion
in reply to: karl1112
Does iw->3dsmax link have any better material names support as FBX export?
What Lumion is? It's quite popular and easy to use visualization software for architects, check http://lumion3d.com/
Tags (3)
Rail Community
