InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Infraworks 2015 vs Infraworks 360- edit roads
2 REPLIES 2
NDM_USER
782 Views, 2 Replies
I have imported an imx file with roads and surface using Infraworks 2015 - (Ultimate Suite). I can't edit the roads or change the default style with the desktop version however in Infraworks 360 I can . Beside the fact that Autodesk wants more money from me ........Any ideas why is this happening?
Second issue - In infraworks 360 everytime when I change the road style the road profile gets burried to zero elevation , To fix the  profile issue you need to go back to geometry editor and hit recreate profile. ..
Cheers
Dorin
2 REPLIES 2
tcorey
in reply to: NDM_USER
@dvemis wrote:
I have imported an imx file with roads and surface using Infraworks 2015 - (Ultimate Suite). I can't edit the roads or change the default style with the desktop version however in Infraworks 360 I can . Beside the fact that Autodesk wants more money from me ........Any ideas why is this happening?....
Yes. Autodesk removed that feature from InfraWorks 2015 this year when they decided to offer InfraWorks 360. That is one of the features that differentiates InfraWorks from InfraWorks 360.
I don't like that Autodesk decided remove alignments from IMX Export. Being able to bring alignments from InfraWorks would be a significant workflow enhancement and it's one that was present last year. Autodesk, keep the profile creation and other higher-end functions in 360, but give us back the ability to export alignments.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Karsten.Saenger
Hi Dorin,
regarding to the second issue you mentioned - this is a known program limitation in the current version. The workaround is - as you said - to recreate the profile.
The Autodesk InfraWorks development team is working on a fix for one of the next product cycle releases.
Karsten.
Karsten Saenger
Rail Community
