I have imported an imx file with roads and surface using Infraworks 2015 - (Ultimate Suite). I can't edit the roads or change the default style with the desktop version however in Infraworks 360 I can . Beside the fact that Autodesk wants more money from me ........Any ideas why is this happening?
Second issue - In infraworks 360 everytime when I change the road style the road profile gets burried to zero elevation , To fix the profile issue you need to go back to geometry editor and hit recreate profile. ..
Cheers
Dorin
Solved by Karsten.Saenger. Go to Solution.
@dvemis wrote:
I have imported an imx file with roads and surface using Infraworks 2015 - (Ultimate Suite). I can't edit the roads or change the default style with the desktop version however in Infraworks 360 I can . Beside the fact that Autodesk wants more money from me ........Any ideas why is this happening?....
Yes. Autodesk removed that feature from InfraWorks 2015 this year when they decided to offer InfraWorks 360. That is one of the features that differentiates InfraWorks from InfraWorks 360.
I don't like that Autodesk decided remove alignments from IMX Export. Being able to bring alignments from InfraWorks would be a significant workflow enhancement and it's one that was present last year. Autodesk, keep the profile creation and other higher-end functions in 360, but give us back the ability to export alignments.
Tim
