I just got "upgraded" to Infraworks 2015 and am somewhat dissappointed. Is anyone else having problems with menu lag? I click on a command or add a new keyframe to a story board and I have to wait approx. 25 seconds for the action to take place. Layers load much slower in 2015 than they did in 2014 R2 and in some cases it took me 4 hours to load an image in 2015 where in 2014 R2 it took 12 minutes. Is there a forum to vent about Autodesk related issues? Or maybe a trained therapist equipped to handle these emotional issues Autodesk is putting me through?
I'm having issues with deleted artifacts remaining in the scene. I keep having to regen the environment to clean-up artifacts. Going back to 2014.
What kind of artifacts? I know that if I import a shapefile that represents a pipeline and if I subsequently change a node (Move in X, Y, or Z) then Infraworks will automatically create a copy of that pipeline. If I delete said shapefile from the environment that copy will still be there so I have to delete that as well. I actually don't mind this but I can see how it could be annoying.
Road artifacts... I'm simply adding plants and sidewalks from the existing library. I was changing the lane configuration and the intersections and needed to delete and re-create a section with an additional lane. 2015 deleted the road section but left a section of road at a 45 degree angle and I couldn't delete the road. It did remove itself when I did a regen. This happened a couple of times... The regen is too slow for a fix.
Attached are two images showing the difference in times importing a 2GB sid image between 2014 R2 and 2015.
