InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Infraworks 2015 360 Roadway Design - intersection radius
1 REPLY 1
k.lew
959 Views, 1 Reply
I'm trying to specify a large intersection radius for one of my roadways and cannot.
I'm having issues getting the "turning zone" to appear so that I can have the radius curve point to edit.
This particular intersection jogs slightly (see attached Infraworks capture and AutoCAD linework). I think this is the reason I can't get the radius curve to show up.  Anyone know how to do this manually or a workaround?
1 REPLY 1
Karsten.Saenger
in reply to: k.lew
Hi Kelsey,
a similar issue was raised for internal discussion recently.
Unfortunately this is as designed in the moment but there is a workaround:
If you connect the two secondary roads the intersection should appear correctly. It is important to have a slight offset to the alignment of the primary road, the two alignment should not overlap in this area. You might also need to change the elevations to clean up the intersection.
Karsten
Karsten Saenger
Rail Community
