InfraWorks Forum
Welcome to Autodeskā€™s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
IMX FILE CIVIL3D TO INFRAWORKS
4 REPLIES 4
jfeijo
561 Views, 4 Replies
WHEN I EXPORT IMX FILE FROM CIVIL3D 2014, THIS COMMAND EXPORT EVERYTHING (SURFACES, ALIGMENTS) EXCEPT THE PROFILES. I DONĀ“T KNOW WHY...CAN ANYONE HELP ME?
TKS
JOAO
4 REPLIES 4
ToddRogers-WPM
in reply to: jfeijo
Why do you need a profile in Infraworks?
Todd Rogers
jfeijo
in reply to: jfeijo
I need the information of corridors.
I want to create multiple scenarios in a technical viability study of an airport. Need to see the fill/cut impact
jfeijo
in reply to: jfeijo
Create by polyline from corridor and then export sdf file. the interoperability is not as much autodesk advocates
dsimenic
in reply to: jfeijo
Try to experiment with Horizontal and Vertical elements of alignments.
(use more element method instead of tangents).
In some situation (different types of alignment elements) Infraworks import C3D alignments like a spline, in other like a design road (meaning, you can't split the road).
Rail Community
Ā
Ā
