InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Import Issue from Civil 3D misaligning
1 REPLY 1
467 Views, 1 Reply
I'm having issues aligning different file types created in civil 3d when I import them into Infraworks 2015.  I have 4 files types I'm using, .fbx (for objects), .sdf (for 3-d polylines), .xml (surface), and .rcp ( point cloud).  In civil 3d everything lines up with each other and looks great.  When importing these file types into infraworks my .sdf file matches the .xml, the .fbx files match within themselves but not .sdf, and the .rcp match neither.  Everything is close, but not spot on, it varies from +/- 2 feet to spot on for both the vertical and horizontal.  I thought this could be fixed with a rotation or a constant move but it varies in such a way there is no constant fix that would solve this problem.  I'm not sure what's causing the objects to misalign, the project is 7 miles long, so I was thinking maybe its pulling in differing origin points or something.
All file types were imported using the same coordinate system within infraworks and I've even tried both setting my coordinate system in civil 3d to match that of infraworks (CAIIIF state plane) and not setting the civil 3D coordinate system and I get the same results.  If anyone has had any luck with importing multiple files types and can help me with this issue that would be great.
Also, is there a way to change the color of a point cloud if not RGB values are present.
Ross Doyle
1 REPLY 1
elliott.rosenfeld
Hey Ross,
The newest release of Autodesk InfraWorks 360 2015 (December 2014 release, aka version 2015.3) was released today.
We have dramatically enhanced the interoperability between InfraWorks and AutoCAD Civil 3D.
Please take a look at What's New for InfraWorks 360 (December 2014 release) for more information about this, and other new enhancements: http://help.autodesk.com/view/INFMDR/2015/ENU/?guid=GUID-5CD0E45F-B2F7-4A96-8A4B-C37110FD81A1
You can also check out our new online Help chapter on Exchanging Data Between Civil 3D and InfraWorks: http://help.autodesk.com/view/INFMDR/2015/ENU/?guid=GUID-03CD8D13-2192-4561-B5C1-18D7069F3DBF
Additionally, for help with Coordinate Systems, please read this recent BIMagination blog post: http://autodesk.typepad.com/bimagination/2014/12/best-practices-for-using-coordinate-systems-in-infr...
Elliott
Principal Specialist, Infrastructure
Rail Community
