I published my model, and even sent invites to others, but cannot figure out how to have others view the model through a web page.
I know they must install the web viewer plugin, and did so on my machine, but how do I generate a link to view it through the web?
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Solved by tomfukushima. Go to Solution.
The sections about Scenarios on the WikiHelp (http://wikihelp.autodesk.com/Infrastructure_Modeler/enu/2013/Help/0185-For_Subs0) describe what you are looking for.
I see. I went through the steps and am publishing the scenario now, its taking quite a long time. 20 minutes so far, just done now.
The help is a bit annoying, in that you have to go through three pages to find where a command is. they say to make a storyboard at first, then do not mention the ribbon location for quite a while, its not always obvious where a command is, especially since there is no command line.
Glad you got it working and thanks for the feedback on the help.
Cheers
actually its not working on anything but small models.
I get crashes when setting the image size to 4096.
I still need feedback from autodesk on the min and max params for those settings and what they have found to work and not.
Yes, I'm working on getting that information, and should have something for your other thread.
shoot, I replied to wrong thread. Thanks for your help so far.
I am also having issues publishing to the web. I have created the account, logged in, published to aim360. It now just says sync, however when i log in to aim360.autodesk.com i do not see my model. Am I missing something?
You will need to publish a scenario to see something on aim360.autodesk.com. More information about scenarios can be found here: http://wikihelp.autodesk.com/Infrastructure_Modeler/enu/2013/Help/0217-For_Subs217/0261-Create_S261
Tom
Google retired support for the IE plugin. What are the plans to allow organizations with IE as the corporate standard to access the scenarios? Bit fustrating..
Thanks for any light on this,
Leo
