InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
How to project work to raster Terrain Surface
1 REPLY 1
mongoosest3
444 Views, 1 Reply
I had imported the Terrain model as a vector import and notcied after I got done putting in 75% of my proposed parking areas, landscaping and roads that I should have used the Raster image for the terrian model.
So I imported the raster terrain and I got the enclosed look and feel. It appears that all my work is set at 0 elevation and it looks like it is sunk into the ground. How can one reproject the work to the raster ( true surface) without starting over?
1 REPLY 1
in reply to: mongoosest3
Check the "Drape Options" of the Data source and you can play with the 'Set Elevation' vs 'Drape' to see if that helps to set them appropriately.
Partha Sarkar
Rail Community
