I can't find how to login into infraworks 2015. Help is appreciated:)
Solved by Karsten.Saenger. Go to Solution.
which infraworks did you download: http://www.autodesk.com/products/infraworks-360/compare-products
there are 2 different ones
DarrenP
hi,
on the older entry page which has the black background, you will find the login under the Collaboration section on the lower left.
Having the new HOME which has the bluish beckground and bigger tiles of the models you will fin the login in the upper utility bar on the far left end.
In both cases you need to have an ADSK account which can be created there as well.
Andreas
Hi Aivaras,
please note that the student version of InfraWorks is no InfraWorks 360 but the standalone InfraWorks which is the same as the "InfraWorks in a Suite" version.
See this page for a comparison: http://www.autodesk.com/products/infraworks-360/compare-products
That being said, you do not have any cloud collaboration features available.
The InfraWorks 360 will probably available as a student version as well in the future.
Karsten.
Thank You all for support. I was surfing a lot about infraworks and other products. I am a student and I need Infraworks 360 for my Master's work but unfortunately at the moment only Infraworks is availiable for students. I even wrote a letter asking for exception in getting license for InfraWorks 360 because I need Bridgles and roads module. 30 days trial is not what I need for my 2 years work. Sad, but my request was denied 😞
