Dear All,
kindly help me to locate my location in infraworks
If i understand your question correctly, you would want to open Application Options, select the View tab, and enable the Status bar.
Once you have done that, point your mouse anywhere in your model, and look at the bottom left corner of the application window to view geographic coordinates for your cursor's current position. You can change the units from feet to meters using the Unit Configuration tab of the Application Options dialog.
