I have an AutoCAD solid in a dwg (it is a circle swept along a path to represent a pipeline; I've got no time to create a Civil 3D pipe network) and the question is how to bring it in to Infraworks to show the solid circular shape.
I have the dwg showing up in Data Sources but am unsure how to configure it....
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by neilyj666. Go to Solution.
I just created a 3D poly along the invert and imported into Infraworks as a Pipeline and adjusted the size in the style to suit
