Need to build piers and marinas. Any tips?
I would suggest importing 3D models.
Or, for a pier/dock, you could try sketching a design road that extends into the water from the land, then right-click and select Add bridge to turn that strech of design road into a bridge, aka pier. You would have to modify the bridge "clearance height" to change its elevation, and change the number of piers as well as mess with the road/bridge material styles to get it look right, but it could be done.
Would that work for your intended project?
