InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
How do I render a storyboard video?
17 REPLIES 17
Message 1 of 18
3417 Views, 17 Replies
The "Export Storyboard" option in the Storyboard panel seems to only give me choppy videos that looks like the real-time visualization.  Is there a way to do a high-quality video like the "Render" panel in the Imagery group?  If not, any suggestions on how to eliminate the stuttering?
17 REPLIES 17
Message 2 of 18
ToddRogers-WPM
Sounds like you didn't put the storboard together properly.  However, there are some settings to change...
1.  Pick the format you want to use (windows media, etc.).
2.  Click the Properties button.  If you want high quality, change the bit rate to 10,400.
3.  Change the Frame rate to 24.
It will take longer to process, but this is for HD quality.  If you like, you can check out some of my videos I have produced using these settings...
http://www.youtube.com/watch?v=TU-0ngG0kFo&feature=c4-overview&list=UUn_oTgJkFtpVUSz0VMbgiDA
Todd Rogers
Message 3 of 18
LeafRiders
in reply to: ToddRogers-WPM
What resolution do you set in combination with these property settings? Thanks.
Message 4 of 18
ToddRogers-WPM
in reply to: LeafRiders
1920 x 1200 is what I use.
Todd Rogers
Message 5 of 18
dgorsman
Resolution will depend on your target viewing device.  For old-style monitors, you will be using a 4:3 aspect ratio, such as 800 x 600.  For HD televisions or monitors, you should be looking at 16:9 aspect ratio 720p (1280 x 720) or 1080p (1920 x 1080).  Higher resolutions will take longer to process and may crash otherwise marginal hardware set-ups.
Message 6 of 18
k.lew
I know this is an old post, but I thought I'd add my input in case you're like me and looking for solutions all across the forums. Smiley Wink
I couldn't get my video to export without horrible choppiness and stuttering all over the place.  I tried all sorts of export settings, and finally found that it was actually because I was exporting to a network drive.  Unfortunately, Infraworks and network drives do NOT cooperate.  Exporting my storyboard to my local HD created a seamless video 🙂
Message 7 of 18
neilyj666
Not really experienced any issues with creating videos on a network mapped drive; all my Infarworks data sources are on network drives
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 8 of 18
k.lew
Interesting.  Out of curiosity, do you build/save your projects on network drives?
we've had a bountiful number of issues and autodesk has told us it's all due to having our projects on network drives.
Message 9 of 18
neilyj666
in reply to: k.lew
Yes I do all my Infraworks work via a network drive but I've never tried via my local SSD drive which may speed up the creation of videos.
Message 10 of 18
k.lew
in reply to: neilyj666
wow I'm impressed! We've had incredible instability and a plethora of other issues, all of which Autodesk blames on the fact that we're working off network drives.
Message 11 of 18
neilyj666
in reply to: k.lew
Attached an example of one of my data paths - the L drive is a locally mapped network drive
It seems a bit bizarre that Autodesk are so keen on pushing cloud solutions (that few people want or need) and yet neglect the good old network that most everyone still uses....Smiley Frustrated
Message 12 of 18
tcorey
That image shows the path to an image file. Where is the project file, the .sqlite?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 13 of 18
neilyj666
in reply to: tcorey
Pretty sure it is in an Infraworks folder under Civil folder but I'll check
Message 14 of 18
neilyj666
Yes the sqlite is on a mapped network drive
Message 15 of 18
I was having the same issue.  I found that the issue ended up being that I still had Infraworks open when I was trying to play the video.  After I closed Infraworks, the video played very smooth.
Message 16 of 18
Can anybody please tell me how can I save video from storey board ??
I am not sure how to proceed after this.
Thanks in advance
Message 17 of 18
here's a help topic that should walk you through it! Let me know if you encounter any issues.
http://help.autodesk.com/view/INFMDR/ENU/?guid=GUID-02120183-1827-4FEE-BED2-0CFE7CA04C90
Best,
Elliott
Principal Specialist, Infrastructure
Message 18 of 18
parteekwitt
in reply to: parteekwitt
No worries, I found it
Rail Community
