InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Getting the pre 2015 skies back
1 REPLY 1
neilyj666
429 Views, 1 Reply
I created a support case regarding the old skies (dawn, noon etc etc) and they are not available directly as they were in  2014 but can be "kind of used".
The workaround is as follows - kudos to Nicolas Menu at Autodesk Support for this:
There is a workaround to get your old skies back...
Open your model, open the JavaScript console, copy, paste and run this little script...
Setting the SykType to a value of 1 and knowing the correct SkyTextureFileName will switch to the other old sky types; a value of 2 sets the old default sky and s value of 0 will completely remove the sky. After changing the parameter SkyType you have to close and re-open your model, but the script does this for you.
var citymodel = app.ActiveModel;
citymodel.SkyType=3;
citymodel.SkyTextureFileName="";
var modelUri=citymodel.ModelUri;
app.CloseDocument();
app.OpenDocument(modelUri);
 Example to display your model with the Dawn sky
(located in : C:\ProgramData\Autodesk\InfraWorks\Resources\materials\Sky)
citymodel.SkyType=1;
citymodel.SkyTextureFileName=":/Resources/Dawn.dds";
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
1 REPLY 1
Karsten.Saenger
in reply to: neilyj666
Hi @neilyj666
the procedure you are talking of is also described in the Autodesk Knowledge Articles:
http://knowledge.autodesk.com/article/How-to-get-InfraWorks-2014-Sky-Options-and-styles-in-2015
With the introduction of Design Views in InfraWorks 2017.2 the workaround via JavaScript does not work anymore.
If you want the old sky option back I suggest to post it on the InfraWorks Ideas pages: http://forums.autodesk.com/t5/infraworks-360-ideas/idb-p/129/tab/most-recent
Karsten.
Karsten Saenger
Rail Community
