I am about to begin my 1st real project with InfraWorks. I have a couple questions regarding the proper file storage workflow. We currently have the 2015 version include with the suites. I dont think we will be moving to the token based 360 cloud model very soon.
Thx.
Solved by Karsten.Saenger. Go to Solution.
Hello Kelly,
- I know too little about Projectwise and how it works with files and folders. To stay on the safe side I would say it is not possible to use InfraWorks models with Projectwise. The same with Vault - InfraWorks is not designed to be integrated with Vault.
- InfraWorks projects can only be located on local storage if you work with a release 2015.2 and earlier. With version 2015.3 a file open check has been introduced so that a model can only be opened once at a time. This means the models can also be created on a network drive.
- When you add data to an InfraWorks model the current state of the source data is moved to the model folders. You can remove the source data from a drive and the InfraWorks model will still work. However if you want to reconnect ar refresh imported data with the corresponding source data you will have to have it available.
Best Regards,
Karsten.
