Everytime I attempt to create a new proposal I get the error message "failed to create proposal..."
Has anyone had any troubles or have a solution to why I cannot create a new proposal?
Are you creating to a network drive? If so, try creating to your local hard drive.
Does this happen with all projects or only certain projects?
Is there a workaround this problem? I'm on a network drive (as are all the source files for the model) and I haven't been able to create 1 proposal in the file, as I get that error no matter what. One of the reasons I'm using this software was for the use of the proposal feature, which I'm unable to use!!
I was able to successfully, after a bit, get this workflow to work. Takes a while to backup the file though. Afterwards I opened up the drawing and was able to make new proposals. I'm assuming that after one of several program crashes I encountered while building the master proposal caused a minor corruption that was only impacting new proposals.
http://forums.autodesk.com/t5/InfraWorks-General/crash-on-start-up-corrupt-file/td-p/3932402
Did you try the workflow I posted above in that link? Its a bit time consuming depending on your file sizes, but it fixed my file, and allowed me to create proposals. My file at the time must have gotten corrupted during a crash.
