InfraWorks General Discussion
*Expert Elite*
343 Kudos
Post 1 of 3
Eye and Target points
98 Views, 2 Replies
02-26-2014 08:29 AM
Is there a way to specify an Eye and Target points for a model?
I have several different models of the same project but want to show the same view as a screenshot
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
11 Kudos
Post 2 of 3
Re: Eye and Target points
02-27-2014 02:13 AM in reply to: neilyj
I guess bookmarks or the right choice for this, but.. you'll have to do some jerky manual gymnastics (as long as there is no import/export bookmark feature and JavaScript API for setting the current Home Position of a model): 1. Set the view to what you want to be used for your models thumbnail 2. Create a bookmark for that view 3. Apply the current view as Home Position for the model using the ViewCube 4. Go to the YOUR_MODEL.files\unver\Bookmarks folder of the model 5. Inspect the contained bookmark .json files to find the bookmark from (2) (look for the bookmark name you used in (1)) 6. Copy the bookmark .json file to all the other models that should use the same view for their thumbnail 7. Apply the bookmark view as Home Position for each of the models => go to the "imported" bookmark => Apply the current view as Home Position for the model using the ViewCube
Active Contributor
11 Kudos
Post 3 of 3
02-27-2014 02:14 AM in reply to: jutters
It seems all my formatting/layouting gets removed from the posts today :smileysad:
Post to the Community
New Post
