InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Eye and Target points
2 REPLIES 2
neilyj666
322 Views, 2 Replies
Is there a way to specify an Eye and Target points for a model?
I have several different models of the same project but want to show the same view as a screenshot
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
2 REPLIES 2
jutters
in reply to: neilyj666
I guess bookmarks or the right choice for this, but.. you'll have to do some jerky manual gymnastics (as long as there is no import/export bookmark feature and JavaScript API for setting the current Home Position of a model): 1. Set the view to what you want to be used for your models thumbnail 2. Create a bookmark for that view 3. Apply the current view as Home Position for the model using the ViewCube 4. Go to the YOUR_MODEL.files\unver\Bookmarks folder of the model 5. Inspect the contained bookmark .json files to find the bookmark from (2) (look for the bookmark name you used in (1)) 6. Copy the bookmark .json file to all the other models that should use the same view for their thumbnail 7. Apply the bookmark view as Home Position for each of the models => go to the "imported" bookmark => Apply the current view as Home Position for the model using the ViewCube
jutters
in reply to: jutters
It seems all my formatting/layouting gets removed from the posts today 😞
Rail Community
