I am confused by "Drape" and "Don't Drape" options for roads and railways. If I use "Don't Drape", the roads are at correct height but the terrain isn't level with the roads. How can I fix the problem?
Drape: turns 3D geometry into 2D geometry by ignoring the Z-coords; the resulting 2D geometry is then "draped" onto the terrain surface and the vertices are adjusted accordingly to follow the surface.
Don't drape: doesn't change the imported geometry with respect to its dimensionality so it keeps the Z-coords of the input geometry.
What you probably want for your roads is to apply a "bridge" road style to some of roads so they get detached from the terrain surface...
Is it possible to select a group of vertex on a road and delete them? Is it possible to move a vertex using the move tool instead of height/elevation tool? I think that "Split Feature" command doesn't work. After adding water to a pond and working on roads for a while, I tried to delete the water but AIM crashes with Autodesk's send/don't send message.
Could you please start a new thread for new unrelated topics...
Answering your questions:
1. I would like "Select a group of vertices" added to next version of AIM.
2. I can move a vertice up or down. I can't move a vertice left, right, backward, or forward.
3. I thought the split feature doesn't work but I found out that if a split a road into three pieces and replace the middle piece with a bridge, the road and bridge surfaces don't end where the road was split. Either road or bridge surface extend beyond the split.
4. I thought that the water object was too low and I tried to move it up a little bit but it didn't work. AIM crashes every time I try to delete the water object.
