I'm trying to get a model in AIW's that shows a mosaic photo draped over a surface for some 3d views. Problem is that it doesn't seem to matter what I use for a terrain surface to drape the photo onto, whenever I add a terrain datasource (dem, rcp, etc) the resulting after it refreshes and imports is that all my data disappears on the screen with the exception of one layer which is a 3d layer. All the rest is gone and there is no terrain surface showing up. When I delete the terrain layer, the rest reappears.
Thanks.
Hi Kent,
Based on your descrption, it sounds like you may have a 'units' issue happening here. InfraWorks uses metric units be default. If the terrain surface is imperial, there is no auto-conversion when importing.Check your InfraWorks project settings, and also make sure the Coordinate Systems match between your source data, and the project settings in IW.
Also, I have seen this same issue when importing RCP files that were processed in ReCap. This article explains how to properly import/process point files in ReCap so they lineup/scale correctly when importing to InfraWorks.
I give your suggestions a try. I did have some success using a contours file as the terrain datasource which works but the contours don't give as accurate of a terrain model as I would like.
I'll keep you posted.
