I have some problems to download models from the model builder in Infraworks 360
When I selected a polygon and click download, autodesk send me a confirmation mail. In the home interface in the collaborate part, I click download in the model, and an error message shows on the screen '' Unable to download the model ''x'' See the Message Log for further details''. (See image 01)
How can I fix this?
Best Regards
Hi there,
I think this may be due to a needed update. See the attached image:
Also, if you go through the update process but are still unable to download your model(s), please write back and provide the log file as an attachment if possible.
Thanks!
Elliott
Thank you Elliot. I already made all the steps and updated from the subscription center. I have another interface home. If you see the image, I have another message for more updates (re-installed) I have to made this whatever times need to get the model builder work?
Best regards
Hi there, my apologies for not checking in sooner. Were you able to resolve this issue?
Thanks!
Elliott
Hi
I have Infraworks 360 and it will not let me download the models from the Model Builder
Message :
Unable to download the model - see message log
Message log:
Error
ServiceException.cpp 55 Service Exception:Failed to close the remove feature respository. File Name : Managers\Model\ModelDownloadManager.cpp
I have attached the log file
I have the same problem here.
If someone knows how to solve this problem, please help us.
So last week I was able to download the models built, this week I cannot again and these are the lissues in the error log.
file: GitRepo.cpp
line: 121
message: GIT error: fatal: unable to access 'https://infraworks360.autodesk.com/accts/2b142eac000911e5b59022000b688268/git/11750/39098/feature.gi... SSL certificate problem: self signed certificate in certificate chain
file: Service Exception.ccp
line: 55
Message: Service Exception: Failed to clone the remote feature repositry, File Name: Managers\Model\ModelDownloadManager.cpp
Any solutions to this.....
Somedays it works and others it will not?
Same two messages again #121 and #55 when downloading a new Model
