InfraWorks General Discussion
BrianHailey
Message 1 of 4 (675 Views)
Displaying Rivers
675 Views, 3 Replies
09-02-2012 12:41 AM
So, if you have a .shp file representing the flowlines of rivers and streams, what's the best way to display that? Water areas don't work, right? They have to have an enclosed area and all I have is the flowline of the streams. Create a road style that looks like a river? Any other ideas?
Brian Hailey
CAD-1.com
My Blog
There is an easier solution to this: when importing the data and after selecting the target type "Water area" there is this field "Buffer width": this can be used to turn the line string/polyline into a polygon. This field can be either mapped from the imported data or set to a constant value. and then you can chose an appropriate water style.
And a remark to the water surface: you can also use the special "water shader material" (dynamically animated and reflective) as material for the different street track materials; there should be no need to import your own water texture.
TRogers
Message 2 of 4 (669 Views)
Re: Displaying Rivers
09-02-2012 07:28 AM in reply to: BrianHailey
You are correct.  You  have to have a closed area for the water style.  And you are also correct in that you could create a road with a "water" surface.  You can grab a picture of water off the internet and assign it as a material.  Should work for you.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Employee
konstantin.baumann
Message 3 of 4 (660 Views)
09-03-2012 01:22 AM in reply to: BrianHailey
BrianHailey
Message 4 of 4 (658 Views)
09-03-2012 09:18 AM in reply to: konstantin.baumann
The buffer width works like a charm! Now if only my dataset had the width of the stream in it.
Brian Hailey
CAD-1.com
My Blog
