I was wondering whether its possible to calculate the volume of material that will have to be excaveted or filled to reach a particular defined ground surface using the elevations from the lidar.
Thanks a lot
Solved by Willy_Campbell. Go to Solution.
Hi Tongai,
I need to change my response:
InfraWorks can create Simple Surface volumes. InfraWorks uses an Initial Surface and a Model Surface [for lack of better terms] to generate volumes. Anything imported as a surface in InfraWorks will generate the Initial Surface. Modifications to the terrain from model objects [Coverage Areas, Roads, etc.] affect the Model Surface.
From the InfraWorks (“I”) menu > Analyze your model you can use Terrain Statistics to show simple cut and fill volumes [bound by the red dashed line] – difference between the initial and model surfaces. I added and manipulated 2 Coverage Areas in this example:
Please Note: InfraWorks does not differntiate between Finished or Existing/Original surface design data, even if it is exported as such from Civil 3D, it all comes in as the Initial Surface.
