InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Custom Buildings
5 REPLIES 5
mongoosest3
819 Views, 5 Replies
Custom Buildings
How does one create existing buildings in IW? I have several buildings in a shopping mall ( currently an industrial area with many buildings) with various pad sites that will have buildings. I want to create in the existing conditions scenario, then I want to create another sceario showing the proposed buildings. How do you make these structures?
5 REPLIES 5
in reply to: mongoosest3
Could you check the following link and see if that help ?
http://docs.autodesk.com/ICD/2014/ENU/files/GUID-A847370D-0D7B-46C4-A74F-6EF4584A0328.htm
Partha Sarkar
mongoosest3
Yes I am familiar with changing the facades.What I am referring to is making buildings close to what they look like in existing conditions. So for example a gas station with a particular footprint and roof and canopy would be duplicated. Next to that is a restaurant with a unique footprint and facade. There are about 50-60 buildings on site that need to be duplicated. Putting simple boxes will not suffice. I have tried unsucessfully to insert revit models into Infraworks but get error messages. Moreover Infraworks has a limited file import selection that does not include *.rvt files........
Revit Model import is supported in InfraWorks 2014.
Please check this :
http://docs.autodesk.com/ICD/2014/ENU/files/GUID-47B265F3-267C-453E-A641-CA0A817BF023.htm
'Enhanced Import Support' - > Import Revit models :
Which version / release of InfraWorks are you using ?
Partha
s.rhyne
I recently learned I can pull Google Sketchup models from the Google 3D Warehouse, perform a little cleanup, export to a Collada (.dae) file and import the Collada in IW. Using the Create Building tool I trace the building outline and then drag the newly imported Sketchup model onto the IW building to take its place. The model updates to the Sketchup model and you have control of scale, rotation and placement. It does a surprisingly good job at managing models that have complex shapes and several faces.
in reply to: s.rhyne
I'm very interested to fully understand your procedure. Just right now I would like to do something similar.
So, if I understood well, you created object inside if IW by using it's tool, and somehow joined model from outside (Sketchup) with your building in IW. Why you did not insert just Sketchup model directly to IW?
What is Collada or dae file? If I remember IW can import directly Sketchup model (not sure).
Can you send some picture.
Drazen
Rail Community
