InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Culverts Properties Changing
3 REPLIES 3
BrianHailey
371 Views, 3 Replies
Howdy all!
I have a culvert in my model. When I go to change some properties of it, other properties change as well. Is this as intended? Am I missing a setting somewhere that prevents this from happening?
In the attached video, I have a culvert that was created by right clicking on the design road. It created a culvert with a 144" barrel (even though it was only using a flow of 7cfs).
I decided that this culvert should only have to convey 1.5 cfs (just trying some things to see how it behaves). I then decided that 144" is a bit big for 1.5 cfs so I resized the culvert to 36". After resizing the culvert, I had to add the flow back in.
Ok, so my culvert is sized and has the correct flow but, I think I can shorten it up a bit. It doesn't need to be quite that far from the road so, I edit the end of the culvert and BOOM! I have a 144" culvert again.
At least it kept the 1.5cfs, well, at least until I edit it back to a 36" culvert.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
3 REPLIES 3
What OS are you on?
Todd Rogers
Brian -
It appears that the default flow values in the Drainage Standards is stomping on your flow edits.  That was not the intended behavior.
Rename the CrossDrainage_Imperial.clp that is found in: C:\ProgramData\Autodesk\InfraWorks 360\Resources\Standards\Drainage
Replace that with attached file but rename with the CLP extension.
The 144 inch culvert barrel result is occuring when the sizing routing is unable to calculate a HW/D Ratio of 1.5:1.
Matt Anderson
Product Manager
Excellent! Thanks for the updated file Matt! That fixed it!
On a side note, the file location on system was one folder deeper in "C:\ProgramData\Autodesk\InfraWorks 360\Resources\Standards\Drainage\DesignStandards".
GEI Consultants
My Civil 3D Blog
Rail Community
