InfraWorks General Discussion
Distinguished Contributor
56 Kudos
Post 1 of 9
crash on exit
522 Views, 8 Replies
06-06-2012 05:42 PM
any fixes in the works for the crash 2013 gives when closing?
Does everyone get them for 2013?
internal protected virtual unsafe Human()
http://onesmallstepforcad.com/
56 Kudos
Post 2 of 9
Re: crash on exit
06-13-2012 09:32 AM in reply to: jmaeding
ok, I did a subscription support request on this, anyone getting the (2013) crashes, please let me know.
Employee
4 Kudos
Post 3 of 9
Re: crash on exit
06-13-2012 10:39 AM in reply to: jmaeding
James,
We are researching this.  It is not consistent across machines/platforms etc.  Please make sure you submit the error report if you get it.
Nick
56 Kudos
Post 4 of 9
Re: crash on exit
06-13-2012 11:30 AM in reply to: nzeeben
thanks for the reply.
Let me know if there are any environment issues you would like to know, like what is installed.
651 Kudos
Post 5 of 9
Re: crash on exit
06-14-2012 06:21 PM in reply to: jmaeding
i had this problem to it only happened on the very 1st launch after installation
56 Kudos
Post 6 of 9
Re: crash on exit
08-01-2012 09:34 AM in reply to: DarrenP
autodesk, any updates on this?
Employee
17 Kudos
Post 7 of 9
Re: crash on exit
08-02-2012 01:33 AM in reply to: jmaeding
How often does that happen on your machine? From time to time? Everytime you close AIM? Only the first time you start AIM after a fresh reboot of your system? 32 bit or 64 bit version? ...?
Active Contributor
6 Kudos
Post 8 of 9
Re: crash on exit
08-17-2012 10:52 AM in reply to: jmaeding
Crash on launch - actually it becomes unresponsive and have to kill the process....
Kevin
Kevin Spear, PE
Synergis Engineering Design Solutions
Valued Contributor
0 Kudos
Post 9 of 9
Re: crash on exit
08-20-2012 10:40 AM in reply to: jmaeding
Turns out i needed to repair both .NET Framework components (Extended & Client Profile), then everything worked.
