How can I angle a concrete mixer (or any vehicle) to show it on a slope? At the moment the front wheels are either above the road or below it
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by NateMoore. Go to Solution.
Create a coverage area. After it is created, you can adjust it with the grips.
Thanks Nate - worked perfectly
