I cannot find the icon for changing units from metric to imperial. Someone please tell me on what ribbon, menu, etc this icon has been placed!!
Solved by Karsten.Saenger. Go to Solution.
Hi Charles,
if you are on InfraWorks 2014 you should be able to change the units in the program options that are accessible by clicking on the "I" sign of InfraWorks in the top left corner of the program window. Then open the program options (bottom right).
In InfraWorks 2015 you need to select the "Settings and Utilities" from the tool icons (last icon on the right) and then open the "Application Options".
Regrads,
Karsten.
