I've imported a Civil 3D model into infraworks. I've applied a Terrain default style and I want to change the scale of the style to be larger. I copied a material/Land Cover Style and changed the texture settings width and height from 1X1 to 100X100. When applying this new style to the terrain default, Infraworks ignores my changed texture settings defaulting to a 1X1 scale. If I create a coverage apply my new style it appears as it should.
What is the best method to change the default style scale for Terrains?
Did you try applying that as a Style Rule instead of a Manual Style?
