Maybe I'm missing it, but shouldn't there be an easier way to create a new building facade from scratch with images I want to use? If anyone has accomplished this and has a workflow, I'd greatly appreciate it. Having to edit one from a .json file seems like a lot of work.
Brian
Brian,
If you are wanting the same pattern repeated over the entire building, you can create a material from the image and then apply that to the building. If you are wanting to create the individual cells, then you'll need to get into the .json to do that (as far as I know). I do wish there was an easier way to do this but that's the only way I know of.
