Hello!
I`m having problems importing DWG`s to my InfraWorks R4. When trying to import a simple polygon in dwg 2013-format, I get a "problem" message on the status of the file (see printscreen). Similar imports on my previous InfraWorks-version worked just fine.
Anybody know how to solve this issue?
Frode
For some reason the 2D DWG import was removed in R4, only 3D DWG import has been left. I'm not sure why this was done now, but 2D DWG import has never been the preferred import for getting data into InfraWorks, only SDF or SHP. These last formats can use the extra Object Data attached which in turn can drive attribute values in InfraWorks.
John
