InfraWorks General Discussion
Distinguished Contributor
Matt__W
Message 1 of 6 (424 Views)
Can't edit road (or anything else)
424 Views, 5 Replies
12-10-2013 11:21 AM
I just downloaded the SF sample model and was going through some of the online video tutorials and came to a road block.  I can't seem to select a road (or anything else for that matter) to edit it or look at it's profile.  Admittedly I also recently had AIW installed so I'm not up to speed with everything yet so....  What's the trick to being able to select and ultimately edit ANYTHING?  :smileyhappy:
Thanks in advance!
  Matt
“The illiterate of the 21st century will not be those who cannot read and write, but those who cannot learn, unlearn, and relearn.” ~ Alvin Toffler
Matt__W
Message 2 of 6 (408 Views)
Re: Can't edit road (or anything else)
12-11-2013 05:10 AM in reply to: Matt__W
So it appears to have something to do with the fact that it's the downloaded SF sample model and that it's "connected to online model".  I created a new model and was able to modify things as I had expected.  So the question now is.... is there a way to "break" the link from the sample model but maintain all of the data locally?
DarrenP
Message 3 of 6 (399 Views)
12-11-2013 06:20 AM in reply to: Matt__W
go to the collaborate tab and click on disconnect model
Matt__W
Message 4 of 6 (388 Views)
12-11-2013 06:34 AM in reply to: DarrenP
Hmmm.... still can't edit a road that I just modeled. Even after disconnecting the model, save as (to create a new, disconnected model), add road, can't edit. And just for ha-ha's, I even closed/reopened, added new road and still can't edit. I'm not getting any of the grips. Soooo.... what's going on?
DarrenP
Message 5 of 6 (383 Views)
12-11-2013 07:14 AM in reply to: Matt__W
do you have any other files you can test?
it might be something with file
i can't select any of the roads either in the San Fran model but i can select roads in other infraworks models
Matt__W
Message 6 of 6 (370 Views)
12-12-2013 06:02 AM in reply to: DarrenP
Alright... I figured it out.  The surface layers were LOCKED.  I had to unlock them, then I could modify roads, buildings, etc...
