InfraWorks General Discussion
Distinguished Contributor
jmaeding
Message 1 of 10 (956 Views)
Can AIM model curvature of the earth?
956 Views, 9 Replies
09-18-2012 04:08 PM
I know it uses a tin surface, which cannot wrap under itself, but if I choose a coordinate system like UTM 11, will it drape that surface around a globe? (like google earth)
any suggestions on tools that can do that besides google earth?
I have arcscene and manifold gis progs, just never cared about the effects of earth curvature on what  given viewpoint can see.
internal protected virtual unsafe Human()
http://onesmallstepforcad.com/
AIM requires you to correctly geo-reference your model and based on that can support the earth curvature automatically for all projects... just make them large enough and you will see...
About the atmospheric diffraction you mentioned: I would not expect that in the very near future... :-)
spatialguru
Message 2 of 10 (950 Views)
Re: Can AIM model curvature of the earth?
09-18-2012 08:56 PM in reply to: jmaeding
The two that come to mind are ossimPlanet and WorldWind (though I don't know WW really much at all).  ossimPlanet is totally built on a global model and can do some great stuff.  You'll probably want to extend it further for your particular solution but it might be more inspiring than google earth at this point.
Enjoy!
http://trac.osgeo.org/ossim/wiki/OssimPlanet
http://download.osgeo.org/ossim/installers/
Geo-geek, Publisher, Author
http://LocatePress.com
http://WebMappingIllustrated.com
http://actian.com/products/ingres/geospatial
Employee
konstantin.baumann
Message 3 of 10 (943 Views)
09-19-2012 07:59 AM in reply to: spatialguru
Yes, AIM supports the earth curvature automatically...
jmaeding
Message 4 of 10 (938 Views)
09-19-2012 09:07 AM in reply to: konstantin.baumann
what do you mean by support though? Does it always use a "foundation" of a globe?
I would think it depends on the models coordinate system, projected or a non-projected system.
Another interesting issue is atmospheric diffraction, which I heard usually takes away about 1/2 the effect of curved earth.
So you see over the horizon a bit as light follows the earth. Now that would be an impressive model!
Employee
konstantin.baumann
Message 5 of 10 (936 Views)
09-19-2012 09:14 AM in reply to: jmaeding
jmaeding
Message 6 of 10 (934 Views)
09-19-2012 11:38 AM in reply to: jmaeding
I will try using UTM or something
spatialguru
Message 7 of 10 (931 Views)
09-19-2012 11:57 AM in reply to: jmaeding
Totally off topic from AIM, but I forgot to mention, depending on capabilities you need or real-time spatial dynamics, you might also be interested in http://cesium.agi.com/
Employee
heiko.meyerdirks
Message 8 of 10 (921 Views)
09-20-2012 03:08 AM in reply to: jmaeding
Hello
If you choose an UTM zone you will restrict your model extend to the valid extend of that specific UTM zone. To work in a world context, it is best to use a worldwide valid coordinate system (CS). Therefore I would recommend not to change the database CS as LL84 is worldwide valid.
You will not gain anything by changing the database CS and you can still change the display of the coordinates any time by modifying the User Coordinate System.
Heiko
Heiko Meyerdirks
Engineering Manager
Autodesk IPG ICP InfraWorks
jmaeding
Message 9 of 10 (917 Views)
09-20-2012 08:31 AM in reply to: jmaeding
ah, thanks for the tip.
I tend to use CA state plane zone 6 prettymuch all the time, so am less educated on the "global" coordinate systems other than figuring out which one is used by a given chunk of data.
BrianHailey
Message 10 of 10 (888 Views)
09-24-2012 06:15 PM in reply to: jmaeding
Here's an example of AIM showing curvature of the earth:
http://screencast.com/t/xqXvIZxULN
Brian Hailey
CAD-1.com
My Blog
