Good Afternoon -
Is there a boundary clip or some sort of boundary condition that allows a user to import all data necessary for a project for whole area but clip out only what you need to work with at the moment? For example, I have a Mr. Sid file for a a county extent (fairly large file) which takes up about 10-20 minutes of load time. It takes four NED files to give provide a 3-D image of the surface for that county. My project today may be in the west end of the county but the project tomorrow is in the eastern portion. I know I can bookmark locations but I did not know if I could bookmark locations with only certain segments loaded for that bookmark only and supress the other information so that I get a faster response.
Solved by BrianHailey. Go to Solution.
You can go into the model properties (options?) and adjust the model extents. Not quite what you are asking for but perhaps it could work.
Yes I do believe this will work. I have not tried to setup multiple files because I don't think I can set multiple boundaries up but I think this will work. Thank you!
