Are there any tricks to fine-tuning the field of view / focal length settings when using the augmented reality features in InfraWorks?
If you take a look at the attached image, we've turned off the road and terrain surface, which makes the effect more pronounced. The direction is almost correct, but the field of view and focal length appear to be out of whack. I'm using an iPad Air with AIW 2014 R4. Does 2015 offer any features to improve the augmented reality experience?
Hi John
What you describe is most likely caused by GPS inaccuracy - which can be up to 60m off the actual posisiton. Looks like the app 'thinks' you would be standing left of that road (somewhere up the little hill). There is a second AR mode which only takes device orientation into account but ignores position. So what you could do is manually navigate to the right virtual position and use this orientation only mode.
Best
Manuel
