Hi All,
I am new to this software,
m trying to apply material/color to one face of the object, but it's applying to whole side of the objects
Please suggest me howto apply the colour like i attached in the snap.
Thanks & Regards
Surendra Kumar N
surendra2282@gmail.com
+91 9535217984
Solved by Karsten.Saenger. Go to Solution.
In IW2016 I'm having this issue as well. In 2015 I was able to apply a material which added it to the entire building then I was able to individually add the different facades for individual sides of a building but in 2016 that is no longer working.
How can I get this working in 2016?
Alright, I did get it working again.
- I set the building detail to high
- then I had to apply a canned facade that comes with IW's first. After that I can add my own image per face of building.
The bad thing is taht I want to apply my image as the initial facade material, then go back and change the individual building faces. However, if I use my image first I'm unable to individually add a new material per facade.
