In previous releases you were able to select a tree in edit mode, and when the line around the tree group showed up, you could select the line and it would select the whole group. Now you can't select a group!! Why is this not working now?!?!?!?
Solved by nzeeben. Go to Solution.
Todd, After the initial selection if you left click again on the tree it should select the entire group. Once you get used to it, it is alot easier than hunting down the line to pick.
