InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
AIM 2013 dll Error
3 REPLIES 3
john.de.leeuw
768 Views, 3 Replies
AIM 2013 dll Error
Anybody experienced this error using AIM2013?
Entry Point Not Found
log4cplusU.dll
It sometimes pops up when starting AIM or loading a model
3 REPLIES 3
FSWookie
in reply to: john.de.leeuw
I would take a look at where the data your working on is at and the file structure of how your storing the project.
I have ran into problems when I place the data on a server, (just my personal experience), once I placed it back to local PC I was fine.
I also know that the program does not like it when you change the directories on it.
I hope that helps.
Robert Rien
Can you try to reinstall AIM? This looks like a damaged installation/DLL to me...
Konstantin.B
Software Architect
I saw this error message only a few times and by moving my project to my local drive did seem to cure it, however I have recently been seeing it a lot more, first with projects that I converted, (This is where the moved location came from and it did work for those projects, till now). I tried your reinstall recommendation and this still did not work. Are there any other suggestions?
I can get past this only if I Keep hitting the Enter Key, I just do not know what this is doing to my models if anything.
Some models I do not see the error at all, one common thread that I have see is that I leave the default Datum and open a new project, then edit the models settings to the proper Datum I get this error every time.
So I think that it has to do with changing the units, please verify.
Rail Community
