Greetings,
When a user starts a new Model, there is an option to set the 'Schema Template File' (im_default_schema.xst)
This file probably sets the road/street style, correct?
How do I set the default style used for roads?
Thx,
Kevin.
Solved by ToddRogers-WPM. Go to Solution.
When you click to configure the "connection" for your roads, you can set the default rule style there...
if the user does not set the style a default road style is used, what is the default style?
how can I set the default road style?
Thx, Kevin.
You will probably have to edit an XML file somewhere. There is no place to set the default that I am aware of.
