Infraworks 2014
I need to add a building (the exact same building) at the center of every parcel.
How is this done in Infraworks 2014?
At the moment I am using a DWG as the Data Source, creating Coverage from closed plylines.
Thanks..
Kevin.
Solved by kbarnettza. Go to Solution.
This was way too easy .. well done Autodesk .. InfraWorks Rocks!
In Acad.. generate Points at the nodes
In InfraWorks .. add data source .. DWG .. set Geo Location, set category as City Furniture, set style to the building wanted .. set drape in source ... Close and Refresh ... Houses!!! everywhere!!
