InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
3D Model Draping
2 REPLIES 2
ToddRogers-WPM
1201 Views, 2 Replies
3D Model Draping
When inserting a 3D model with terrain, the model will attach, but it will not drape.  See images...
Now if you look at the back of the building, it attaches to the terrain, but it does not "follow" the terrain...
Any workarounds for this?
Todd Rogers
2 REPLIES 2
scottkent
in reply to: ToddRogers-WPM
You are correct - the model will not 'follow' the terrain.  The best way to deal with this is to have the 'terrain' of your building model match your AIM surface as closely as possible.
Scott Kent P.E.
Senior QA Analyst II
Infrastructure Collaboration Products
Autodesk, Inc.
100 Commercial Street
Manchester, NH 03101
CAusman
When placing models on uneven terrain I use the method described in this Autodesk blog entry to create a building pad of sorts.  Works in reverse as well.
http://atlandsend.typepad.com/at-lands-end/2012/11/how-to-flatten-terrain-coverages-easily-in-aim.ht...
Hope that helps.
Rail Community
