I created a project using model builder. After creation I am unable to configure the roads, terrain or coverage areas. I get this error message, "Source files for the following data are not available"
Solved by Karsten.Saenger. Go to Solution.
Hi @jaalfsGMPGW ,
this is normal behavior.
You can only configure data sources if you have a connection to the original data source.
Model Builder models are created in the cloud and the original data sources are OpenStreetMap data, Bing Maps ans SRTM terrain. The data sources are not downloaded to your computer.
Karsten.
